Understanding your problem of not being able to handle the knives before buying .. it makes getting the 'perfect' one more difficult.
I suggest, if you'd like to try various design & handling, get some Sanrenmus or Enlan/Bee. After trying various models (others got sold or given away), here is what I stay with:
SRM (Sanrenmu) 763 in G10, nice small knife but handle grips is very good.
SRM 710, solid frame lock, I take it as mid size, but grip might be a problem as it's handle is stainless steel. Some models come with coarsed 'inlay' on the non locking slab. It helps.
Enlan EL01 or Enlan EL02, solid large knife with good lockup. EL02 (micarta, quite smooth) is a bit slippery due to smoothness, so I added skateboard tape on it. EL02B might be a grippier one (G10, textured)
Trying to let go SRM 723 as it's so slippery and not good in long cutting session (tried 'shredding' document to thin slips .. )
Since they are cheap to have, you can try many models, and once you know what you like, you can upgrade to better made (steel, handle choice, clip position, etc.) from the major manufacturer.
I found that some liner lock configuration is not to my liking (i.e. too big cutout on non locking slab), frame lock is simpler to clean and dry, axis is fun to flip, well made backlock is not inferior at all, etc. Plus blade grind comparison (flat, hollow, as they don't come in convex
), taper (abrupt or smooth), blade tip geometry, strength, etc.
