- Feb 27, 2006
hello, i have a consistent situation when i grind the bevels on my kmg. every time i start the hand sanding lengthwise from the ricasso to the tip, the kmg scratch lines always disappear at the spine, and the edge first, and persist to be deeper in the center of the blade. i use a grinding jig, and always keep the bottom of it flat against the work rest, so i do not understand how i could be putting more pressure at the spine or edge. are my belts too loose, or too tight ? i get the spring tension arm about horizontal when tightening it. or is it my technique ? here is a diagram of the kmg scratch lines that linger in the center of the blade. thanks for any advise.
