i dig it!I just let a "Gen 1" Work Tuff Gear "Nymph" go (*basically gave it away), in The Exchange, a few weeks back. It sounds like it may meet most of your specs... (*Bohler N690, cryo-treated)
I was about to state the same. But I was pretty sure someone else would have mentioned it before.Wanting it skeletonized and supplied with a sheath might be an issue.
If you wrap it in paracord later, it probably won't fit that sheath. You might need to modify it or get a different one.
the white River m1 fits the sheath with scales and paracord.I was about to state the same. But I was pretty sure someone else would have mentioned it before.
The only exception would be a sheath that ONLY covers the blade, with no interference with the handle area. I recall having one like that STIFF KISS by CRKT (ancient knife, I know). I made a set of homemade micarta scales for it and the plastic seath fit well as it didn't cover any portion of the handle.
I would suggest you find one with scales already in place, but very thin. Unless you plan on going full bushcraft with it and doing power cuts, you don't need THAT MUCH of a handle. If you can do it comfortably with a folder, you should be able to do it with a thin scaled handle.
Mikel
