If your looking for a knife, then you should respond and tell us what you think about our suggestions.
If the rough rider will do what you need, it's cheap enough to carry on a construction site and not feel bad if it breaks, gets dropped somewhere it can't be retrieved from, or "borrowed".
OTOH, if you liked the RAT1 but it's too long, you might look at the RAT2 or the upcoming Zancudo.
http://www.bladehq.com/item--Svord-Mini-Peasant-Knife-Folder--15091
it comes in all colors, it weights less than 2 ounces and you can put a lanyard through the blade tang hole
it is small, non threatening and so inexpensive
OP, you pretty much described the Benchmade Mini-Grip.
2.9" blade + blade length between 2.5" and 3.5" (not over, not under. Preferably between 3 and 3.5)
sheepsfoot + non threatening blade shape. Basically something that no one will think looks "stabby" (leaning toward sheepsfoot, but anything works)
check + handle that is comfortable. I don't care if it's only a 3 finger grip as long as it fits (large hands)
AXIS lock + locking (no need for any high tech hard use type locks. I just will lightly use it to open cans etc)
opening hole + AXIS lock + does not have to be modern (can be two hand open/close)
tip-up, left or right side + preferably with clip (or lanyard hole)
154CM + any worth while blade steel as long as it can be sharpened with rudimentary skills (so not d2 or anything)
commonly found between $60-70+ absolutely <$100, preferably <$50 (I love high end knives, but I don't want to worry about ruining/losing this one)
Benchmade, made in USA + no preference on maker, origin, etc
spyderco manix 2
spyderco delica 4
spyderco native FRN
spyderco salt 1
kershaw leek
case medium stockman
victorinox tinker
you could also check out the spyderco tasman salt. i carry one everyday as my back up edc. that being said i think you should always have a SAK or small traditional knife along with it to accompany the tasman salt. personally i carry a CRK large sebenza 21, tasman salt and a tinker. and that setup works awesome. i would never carry a tasman salt as a stand alone edc because you cant slice with it
Have you considered traditionals? GEC #72 seems to fit your bill nicely. It's not too expensive, back locking, comes in wharncliffe or clip point, beautiful handle materials, easy-to-sharpen 1095 and I think it's comfortable.
I would recommend a Kershaw Skyline. You'll love it!
