Help Me Choose an Outdoor/Survival Folder!!
I'm looking for an outdoor/survival/bushcraft folding knife...
As much as I like a folder for light cutting chores,
…the terms Survival and Folder just don’t go together in my mind.
I feel I need a knife I can trust for heavy work if I get stuck in a survival situation.
Big Mike
”Scaring the tree huggers.”
Forest & Stream
Big Mike
Forest & Stream
not to highjack here but I can say that I always have a folder with me, and not always a fixed blade so in terms of survial tool the one you have with you seems best use what you have, I personally can't carry a fixed blade every where nor would I, but for a trek in the bush I would carry both though,
As far as folders go I would recomend any spyderco, the benchmade skrimish seems like a good knife for the field or even a bigger SAK .
cya
jimi
A good steel like VG-10 or S30V, not something like 440C/AUS8
PS The only knife I have found that fits all of these requirements is the Blade-Tech Pro Hunter Magnum, but that's a bit on the expensive side, so please try to suggest something cheaper!
Not to pick on you at all, but saying 440c and aus8 are "bad" or "not desirable" is a bit over board, I won't pick apart your steel choices, but it really matters how the steel was heat treated, I'm no steel snob either, I'd take a perfectly heat treated 440c knife over a questionable d2 or s30v steel any day. Not to mention, in a survival situation you will probably end up having to sharpen your knife, a softer steel will be easier to sharpen.
Also, a folder may not be in your best interest, I'm trying to understand what you're getting at, fixed blades are wonderful for survival AND bushcraft.
I wouldn't abuse a liner lock by batoning with it.
It seems to be inferred that a folder will be your main knife, while I think that it would be OK for most of what you're looking for, you also are talking about it in a survival situation.
Ruling out a Ritter Grip, a folder with a nice flat grind on it, designed by Doug Ritter with survival in mind is somewhat of incomprehensible to me, I think it's also s30v steel.
Ruling out the right knife because of the price isn't something that should be done, the right tool for the right job means even more when you NEED the right tool. I'm not being condescending but if you can't afford what you need, or what you think you need, your time may be better spent saving up money for the tool you need for your hobby.
Kershaw JYD II meets all those requirements.
ETA: the composite D2 version, that is. The standard JYD II has "only" Sandvik 13C26 steel
Spyderco Manix is simply the most robust pure performer that I have ever used. I have dozens of excellent folders and I keep coming back to it again and again. Mine is reprofiled a tad thinner and I have cleaned dozens of deer with mine and done everything a folder should do. It still locks up like a vault and has very little play. The flat grind is a awesome and the handle is comfortable. Mine is on it's 4th year as EDC I believe.
My .02
I love my Blade Tech Professinal Hunter ,I have the Green G10 & a Black G10 version as well ... I EDC the Green one , just a Fantastic folder... good for Lefties as well tip up or down same with Righties and comes with lock tight .I have owned alot of folders that cost $50-$250 and to me IMO is the best folder for me all others have been sold or traded...
+3 or +4 on the Manix. Other than being a back lock instead of liner, it's meets all the criteria. 3.8" blade, full flat grind, drop point, S30V, G10 scales, full liner, locks up like a bank vault.
I know that it doesn't get much love or attention around these parts (in part because of the lack of an acute point) but the vast majority of your description seems to match the Buck Bravo.
Same here.
I know they are so handy and I'm carrying one within my wallet.
Survival situation will not allow me to choose blade but if I am allowed to,
I'll go for solid fixed blade too.
It doesn't quite meet all of your requirements, but I love my Spyderco Manix to death!!!
My .02
You guys are talking about the Manix, but where are the pictures????
Here, I'll help you out - :D
Doc
This is my current vote. This knife is ugly, it's not made from any wonder steel, it's made in Taiwan, and doesn't have a point. (I should be in sales huh?!)
But, it's got one of the most comfortable handles on any folder I've handled, it's got a tank like build, a lock that makes it as close to a fixed blade as you can get, it holds a good edge and is easily sharpened up to a razor, it's 40 bucks.
You wouldn't regret the Blade-tech Pro hunter magnum. It is worth every penny.
Many good floders would do the job. People have and most people should be able to survive without a knif at all and if they can't, they probably wouldn't make it with a Busse. There may be a big difference in what you would choose under ideal conditions and what you may haved with you in a unexpected event. Many people including me always carry a folder but seldom carry a fixed blade without a reason to do so. For a survival knife for just that reason, most would choose a fixed blade but most all of us carry a folder, Best learn what you can and can't do with the knife that you carry most, That makes it a survival knife.;)
