- Dec 10, 1998
This might help you out.
http://vintagemachinery.org/pubs/detail.aspx?id=5837
Patrice Lemée;12472591 said:Pretty darn close, just a little faster on the 2 higher speeds. More importantly now I am sure. Since I want to do a better job of it and stop guesstimating cutting speeds, I will now measure everything that spins in the shop, starting with the lathe. I will also use it on the new bandsaw with variable drive to see where the appropriate speeds are. (no digital reading of the speed on the drive).
Thanks again for your help guys and once again I highly recommend you get one of those tachometer.
Feel free if you have any questions.
Patrice Lemée;12483378 said:Thanks for the additional info vintagefan. :thumbup:
Doc, just measured the motor speed:
Rated: 1725 RPM
Tested: 1781 RPM
Surprising.
