- Apr 21, 2006
Spyderco mule in one of the stainless releases. M390, Elmax, Cobalt Special, S90V, S35VN, VG10 Damascus,CTS-B75, CTS-XHP and CTS-BD1 . There will be upcoming steels too eventually. I don't know what the next release is. The Grips can be bought with all things needed to put on or take off. There are plenty of folks that offer custom grips for them too.
Though designed to test different steel using knives with the same dimensions and the most suitable heat treatment for high performance cutlery they do make excellent EDC, hunting, skinning, or camping knives. They do kitchen work well as ling as it's not something that demands use of a longer blade.
Some of the releases can be difficult to find on the secondary market and costly too. IMO, they are well worth it. Like true Spyderco products they are designed to cut. Buy the very high performing blade and customize it with your own grip, sheath, etc. I have several and can switch grips onto the one needed as they are all cut & threaded to the same sizes with the exception of Mule #1 in 52100. Not a stainless blade so it's not likely going to be an issue to you.
Mule page: http://www.spyderco.com/edge-u-cation/index.php?item=13
Size & specs :
Joe
Size & specs :
length overall 7.625 " (194 mm) blade length 3.313" (84mm) blade steel: various
length closed n/a (n/a) cutting edge 3.313 " (84 mm) weight 2.7 oz. (76 g)
blade thickness .125 " (3 mm) handle material N/A
Joe
