What makes no difference in operation of the appliance. Each is a current carrying conductor at full voltage reletive to each other.Here in USA typically a 1 ph 220vac circuit will have two hot wires, while in other parts of the world it might be a single hot wire with neutral.
Where you've got that ground wire spliced coming from VFD, please do splice another wire ground there and connect to the ground terminal on VFD. As Nike says "Just do it" {g}
Alright so I thought the high voltage diagram was for 220. Thats not correct though, right? The motor specs say voltage 230/460. So the low voltage diagram is how I need to wire it?
Looks like the only thing I need to do to get it up and running is get a plug on it for 220 outlet wired in and switch jumpers around in controller.
Don't think I'm gonna mess with the 110. Have already moved the garage around to set up grinder by 220 outlet.
Good for you RandyHoly cow i figured it out. Had to change "input frequency source" from "potentiometer" to "panel", whatever that means. This thing is scary at full speed! The 1/3hp little sander i was using looks like the kids toy it is!
