Can you guys post up some pics or ideas to help me choose my next traditional knife?
I'm looking at the Trapper or Muskrat patterns, but I require a wharncliffe for one of the blades.
Any 2 bladed slipjoint with one wharncliffe is fine really. Need ideas. I'm looking to spend up to $200, so customs would be out of reach. Thanks
Do you have a size preference? Steel quality minimum? Carbon steel or stainless?
Case makes/made wharncliffe trappers, but they're hard to find without the bright neon colors. Plus Case's Tru-Sharp isn't exactly CPMS90V. It's serviceable, and easy to sharpen, but edge holding is minimal.
There really aren't many other wharncliffe trappers out there that are worth looking at (Bear & Sons makes some, but aren't high quality).
The better wharncliffe trappers are the GEC Furtakers (also available as the muskrat Furtaker - same knife, just blades on opposite end), but these are quite large and heavy. Calling either an actual trapper or muskrat is stretching the definition IMO, as traditionally these knives have thinish, slender blades made for skinning, and the GECs are anything but thin and slender.
There's a decent amount of Hawbaker muskrats out there. Typically they're 3.875-4.0".
Canal Streets Hawbakers in various handle materials can be had for $70-100. They come in 14-4 CrMo, which is excellent.
Schatt and Morgan (made by Queen) Hawbakers are out there for around $70. 420HC steel at 56-57Rc. Queen also made Hawbakers for themselves, and also for other companies like Robeson and Colonel Coon (all 420HC)
Northwoods made some in D2, but I haven't come across one in quite a while, and the one that I remember seeing months ago was $150.
Keep in mind that muskrats traditionally have fairly thin blades, which'll flex a bit. The clip blades are usually fairly flexible, and the wharncliffe is a bit stiffer simply because of the thicker spine.
Easily the best Hawbaker muskrat is the Case / Tony Bose 2004 muskrat. A couple months ago eBay was inundated with these, but I haven't seen one in a little while. Bone ones were going for around $200, stag for $230-250. If $200 is your limit, it might be worth it to search for a bone one. I have one, and it's my favorite slipjoint.
Here's a pic, with my Canal Street.
