The Tenacious would fit your needs.
Ok, so far the best suggestion seems to be the Centofante 3, followed by the Stretch ( which is not really the same price range as the Endura), and the Tenacious. I am not terribly fond of China made knives, even though I know the Tenacious is a quality knife, but I will put the Centofante 3 and Stretch in my ad. If anyone thinks of something else let me know, Thanks,
Bruce
쌍칼잡이;15638132 said:There is another great folder that comes close to your criteria, but its about 10 dollars more than the Centofante3, and its called Spyderco Pacific Salt H-1 (if you dont mind the rustproof steel).
Here is a direct link to the product. If you scroll down, you can click on the specification tab to see the specs: http://www.bladehq.com/item--Spyderco-Pacific-Salt-H-1-Knife--8214
쌍칼잡이;15634252 said:Spyderco Centofante3 Folding Knife 3-1/8" VG10 Plain Blade, FRN Channeled Handles - C66PBK3 looks to be right around the spec OP mentioned. Here lies the spec (from KnifeWorks description):
Length Overall: 7 9/16" (192 mm)
Length: Closed: 4 1/2" (115 mm)
Hole Diameter: 1/2" (13 mm)
Blade Length: 3 1/8" (79 mm)
Cutting Edge: 3" (76 mm)
Blade Thickness: 5/64" (2 mm)
Blade Steel: VG-10
Weight: 2.5 oz. (71 g)
Handle Material: FRN
Made in Seki-City, Japan
It's under $70.00 @KnifeWorks. I apologize for the prior fixed blade recommendation. I couldn't help but to share it![]()
I don't know if you are seeking or prefer certain blade steel material, but I've heard good feedback with this folder.
