Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I wanted to offer some advice to the OP.
That actuator will likely not hold up. There is a reason that most of the actuators in the 900N range are about three times that price. You get what you pay for, and in knifemaking tools normally you should pay for quality.
Also, you will want a lift type actuator that can support the weight it lifts. A light weight linear actuator often moves things back and forth but does not necessarily support much weight when inactive. The only way they work with much weight is with a scissors jack type lift system.
The motor you linked specs say 9 amps at 230VAC, that is only 2.5HP. A 3HP motor would draw 11+ amps. As I said earlier, you should take the listed ratings on these Chinese goods as wishful thinking. My guess is it delivers a bit less than 2.5HP.
The motor you linked is a 2-pole motor. A four-pole motor running at around 1750RPM will be a better choice. Use the 2X jumper in the VFD for high speed. You will slow the grinder down much more than speed it up. You get better slow speed control with a four-pole motor.
That is a 3HP motor (or so they say). Are you really going to need 3HP??? Will your VFD handle it? You said you have a KBAC-29. That is a 2HP motor drive and if run off single phase input only delivers 6.7amps. If you have a KBAC 29-1P, then it will derate a 3HP motor (assuming the motor really is a 3HP).
I assume you have big enough wiring and breaker for the grinder and other things running off that breaker. From what you have described, I would suggest you need a 220 30Amp breaker and "10-3 with ground" wire to the outlets. That will solve most of your electrical issues. Sometimes it is wisest to bite the bullet and do it right.
