Can you say more about that? Why keep krud kutter away, and what do you recommend as a lubricant for diamond stones?I’d keep the krud kutter away from your knives.
Same here. It's also great for figuring out how far you have to go to reach the apex when you're reprofiling a blade.i bought a cheap usb microscope and that helped me a lot in understanding what i'm actually doing.
sometimes it looks like you put a decent edge on but under the microscope you can see the microbevel.
crisp yes but the depth of the 300 grit scratches will be reflected in the apex line: zig zaggyWith the proper stone technique you can form a crisp apex with 300 grit or coarser stone
Older thread, but I hope I can save someone some grief, and can 100% confirm this. I re-profiled and sharpened a Bradford G3 in M390 and a gen 2 Hogue Deca in magnacut today during a 3 hour session. Heard a lot of people liked using krud kutter so I had picked some up a while back and decided to try it. When I finished and went to wash both knives I found that they both had damage to the finish. Looks dirty and cloudy but doesn't come off with dish soap and sponge, nor with rubbing alcohol, nor with mineral oil. Pretty sure krud kutter ate the stonewash away...Krud kutter if we’re talking about the same thing is a fairly strong degreaser. It could damage/discolor some of the materials used in knives. Also lubricating diamond stones isn’t really necessary.
...Pretty sure krud kutter ate the stonewash away...
Water will reduce clogging.At work we use emulsion on our grinding machines with diamond grinding tools but not to lubricate but to cool down the tool and workpiece.
I only use diamond plates for knife sharpening and I use them dry. I personaly se no benefit to use a lubricant.
During sharpening I clean my diamond plates with a brush.
Thanks everyone for the replies, you’re all very kind and generous with your time; I’m grateful. I’ll try some of these suggestions and see what shakes out.
