ok, thank you. I will post pics as soon as i can. I will try that, thanks for the helpCan you post pics? You can try to carefully bend it back to straight cold since it hasn't been heat treated yet. If that doesn't work, what I might try is this. Put the blade in the oven or forge for its first normalizing heat. When you take it out after the soak it will be very soft. Using a wood mallet or similar, gently tap it straight against an anvil or ceramic tile on a work bench. You don't need a lot of force. Easy does it. You might even be able to use your vise to carefully clamp it straight as it cools. If you don't get it perfect, continue during your second normalizing heat to get it right.
I did some research on that stick, very neat! Thank you very much for the idea!I find a "magebo" or bending stick that was in Murray Carter's book is very useful and can apply a lot of torque also simple and easy to make. The one caveat I will add is it can snap a blade very easily so be mindful of this and do it after tempering the blade and it has just come out of the oven. I made mine out of a scrap 2x4.
Photo:
https://books.google.com/books?id=xw-woxJuDZAC&pg=PT242&lpg=PT242&dq=magebo+straightening+stick&source=bl&ots=a71c5X_XJI&sig=K3aS9voCH24vjrB_3UOgEYkStvc&hl=en&sa=X&ei=cgZ1VY_zPOuIsQShz5vYCg&ved=0CCQQ6AEwAA#v=onepage&q=magebo%20straightening%20stick&f=false
