The Burgh
Basic Member
- Jan 22, 2015
Have done ~ 20 kitchen and field knives on my KME. Generally, very pleased with the tool.
However, I consistently have two challenges:
1.) As I get down to fine and finer grits, and before stropping, I find that the sharpness (nail test, finger test, paper cutting, etc.) decreases. Yes, I do sharpen to "sharp" at every grade stone before moving onto the next finer grade. Do I need to reduce the angle for every succeeding stone (by as little as 1 degree) as I move up, in fineness, in order to preserve the last sharpness apex?
2.) I notice that when the knife is finished, I (and everyone I sharpen for, all knife novices) first examine the look of the edge. My edges are "wavey" on the surface, not a flat smooth surface. (Here I am referring to the surface of the edge, not the line of the bevel.) I suspect that the wave is produced by both the repeated 2" opposing grind and the changes of hand pressure, but I use a very light "weight-of-the-stone" pressure. I have been trying to remove the wave with 1500 grit sandpaper by hand, but then oftentimes remove the sharpened apex.
Can any of you kind BFers suggest some remedies here? Thanks in advance!
