- Sep 13, 2017
Knife looks great!
true, I did not notice, thanks. symmetry is a constant struggle for me.the issues appear to be design oriented.
Another thing I notice, when viewed from above, is the rear half of the handle is not symmetrical side to side.
I have seen that advise too! And I try to stick with it, although I apply it to the side profile, not the "top view". I do not want to flatten the butt too much, but the butt cap sounds like a good idea. Or maybe making the pommel nut protrude instead of grinding it flush.First, the shape as seen from the spine. It looks like poop. I can't remember who said this, but it's good advise, "hold the knife by the blade and then wrap your thumb and index fingers around the handle, if it looks like poo coming out of a butt hole, then you're doing something wrong"
Ever since I read that, I can't help but see poop if handles don't have enough definition.
How to fix it: either flatten the butt end, or add a butt cap or some other feature to delineate the butt from the rest of the handle.
that's the stuff! numbers! thanks a lot. will try that. Your knives were among those that started this itch that I am trying to scratch.Personally, I like the ricasso to be less than 30mm. Around 25mm-28mm feels better in my hand and makes the knife look "faster" (in my opinion).
Thanks for your comments, Fred. I'm sure the finish of the wood could be better. I sanded progressively from 150 to 800, did "water pops" at 240/320, and then sanding
I've found that burnishing, using the edge of a hard piece of 12 ounce leather helps a lot in both pulling the burl pattern of the wood out and also smoothing the surface before adding the finish coat. " Bare down hard." Fred
