This is a current thread on the topic - do a search, there's a ton of info on the site about this. Basically you need to use enough pressure that the abrasive can grind off the burr, but less pressure than it takes to flip the burr. The more they flip, the easier they flip - sometimes one is better off starting the job all over. If the stone you're using is not in good shape, or a poor choice for the steel, it might have trouble operating in the range needed, so make sure your stones are not plugged or glazed.
Formation and removal of the burr is the essence of sharpening, don't give up, just study more.
http://www.bladeforums.com/forums/showthread.php/1235495-Thoughts-on-short-stroke-burr-removal
I feel uncomfortable about insisting on this point, but have you tried the electric tooth brush trick, as stupid as it might sound?
I have not yet tried that trick. So are you supposed to put toothpaste on? That's not a jibe, I've heard of people using toothpaste as a strop compound.
Thanks for your input David. That's what I thought, to be honest.Any toothpaste that's safe for people's teeth will be essentially worthless on a strop for a knife blade; no more effective than bare-leather stropping itself. The abrasive used in most toothpastes is 'hydrated silica', which is mild enough to avoid stripping enamel from teeth. Being so mild, it won't be hard enough to abrade (therefore refine, polish) hardened cutlery steel. Easy way to test this, is to put some toothpaste on a piece of clean white paper, on a hard backing, and strop on it. Look for dark streaks of metal swarf on the paper (I've yet to see this happen). No dark streaks = no metal being removed. At best, if there are loose tatters of weak & damaged steel from stonework done, those'll be scrubbed off. This would also happen on a bare stropping surface anyway (leather, denim, paper, wood, etc), so adding toothpaste wouldn't lend any additional advantage. If one happens to find a toothpaste that actually removes metal from a hardened knife blade, I'd not want to use it on my teeth.
(Toothpaste can polish softer metals, like silver. I've actually done that, just to see if it works, and it does.)
David
David
