HELP WANTED: Modifying a Commander
Jackal
Basic Member
I'm after an Emerson Commander, but will only be interested in I can get someone to "fix" it for me.
Commanders have a double ground blade, but a chisel ground edge. I need the chisel grind to be re-ground to a "normal" double ground 20 degree angle on each side, so I can sharpen it on my Sharpmaker on the "40" setting. I may also wish to have it satin finished to 400 or 600...which ever is a nice, usable finish similar to a Benchmade or Spyderco. Does anyone know who could do this for me? Thanks!!!
-AR
You might have better luck at the "Shop Talk" forum. Whoever does it make sure they know what they are doing. I'd hate to see a Commander go to waste.
Blades
It is possible to do this with your Sharpmaker, but it will need a lot of elbow grease. It took me about six hours in total (and several sessions), but after two weeks I finally had a properly ground "double vee" CQC7A (and I still believe that it should have been like that from the factory, but let's not open the same can of worms again).
Good luck!
