- Aug 13, 2002
Once again seeking the help of the Jewelers on here and of course any one else with casting experience.
This is a small cross I cast in fine silver. I used Delftclay and it worked perfectly. Just need to do some cleanup.
My problem was with trying to cast wire for the pin that will be holding the cross. I used a steel mold especially design for that (sorry no pic) and the result as you can see is less than satisfactory. Forget the larger one, that was just runnout. As you can see I have two cold shuts (not sure if this is the right term). Is it maybe because I did not heat the mold enough or because there is no where for the air to go?
Any tips would be greatly appreciated.
Thanks
Thanks
