Help with DIY machete handle
Alex Topfer Alex Topfer I am still learning to use a machete so it is possible that what I think is great now won't appeal to me in a few years. I will be shaping with files and sandpaper so something a bit soft is desirable. I started by reshaping a factory wood handle but I think I can do better from scratch.
How would CA be as an alternative to linseed oil? I found this description from Bruce Bump; it sounds like it might be just the thing to put a hard finish on birch? I would leave it matte rather than trying to polish it. Is this approachable for a beginner or "danger: keep out" territory?
I don t like CA finish .I do it once and never again .Why should I make from wood plastic ? You need grip on machete not shining handle good only for looking at
N Natlek same, linseed oil over a 600-ish grit final polish gives a good grippy surface for a tool like a machete or hammer. not the most durable possible, but pretty quick to make and replace.
I would like to use Tried & True Danish Oil but I don't want to spend another $28 this project, the current pint cost on Amazon. If anyone is feeling generous I would gladly accept a quantity enough for one large handle.
you can use raw Linseed Oil from kitchen
Mr.Wizard - where in Oregon are you? I'm in Boise, you're welcome to drop by here and use some of mine.
Raw Linseed oil from the kitchen, unless previously boiled, will take weeks to dry. And if you're thinking of boiling your own raw Linseed oil, be very careful, above a certain temperature the oil will flash into a fire and you'll have a hard-to-extinguish oil fire on your hands.
