- Jun 20, 2007
The steel I have been using to make my knives by reduction method is that of an old two man saw. The steel is high enough carbon that if I don' cook it cutting out the blades it will hold a real good edge. It has on every knife so far.
A master baldesmith told me that is would hold a good edge more than likely just as it was. Not to temper because it would make it too brittle, especially without annealing first! On my first blade I spot annealed to allow for drilling the knife handle. The Master Bladesmith said this should be OK as long as I didn't let it carry from the tang into the blade.
OK here is my problem. Even spot annealing I am burning up bits. I have used anywheres from 1/16" bit to 1/4" bits for the holes in the handle even spot annealing or drilling while the spot is red hot. I am only averaging one to two holes per bit! That is getting a little pricy. I even tried the concrete bits someone said would drill OK. They didn't do any better that a standard cobalt bit from Lowes! Two holes if lucky and the carbide is gone.
Question where can I buy small diameter bits that will drill hard steel and what are they called? I figure that if I can buy one good bit of each size and it will keep drilling, I will be ahead of the game. My last knife had 4 - 1/16" holes and 7 or 8 at about 3/16" for glue holes. I burnt up 5 or 6 bits. I am going broke buying small drill bits.
Any help here would be greatly appreciated.
