- Jun 4, 2010
I never got much edge improvement when stropping on plain paper (perhaps some after 200 passes)until I applied slurry to it. Then I noticed a step up in improvement when stropping on leather with the same slurry applied. I think the pores in the leather hold the slurry better. If you don't let the blade get closer to dull then stropping is an effective edge maintenance and saves steel on your blade. Thanks for posting the series of photos and all the effort sharpening that went in to it. Different stone binders will leave a different looking and cutting edge than coming off sand paper. Plus the difference of edge leading or edge trailing strokes. Then I've noticed an edge is capable of push cutting sisal rope coming off a 320 grit Norton India stone. DM
All very true, until I started using real hard backing, I never saw a ton of improvement stropping on paper unless the edge was very refined to begin with. As pressure goes up, I realized I was actually burnishing the edge to some extent but never realized how much till I took the pics. I honestly don't think you could generate those kinds of pressures on a regular stone wrapped with paper.
The Norton India stone is capable of some very fine edges compared to its rated grit value - very clean and tight grind pattern. Sandpaper is not the best demo abrasive, but not bad, especially for discussing edge effects. Have to start somewhere. That India stone is a heck of a tool.
