I've got some full tang knives in the shop, nearly rough ground and ready for HT. There are a couple 5160 blades, a 15N20, and a Damascus one of 1080/15N20. Most will be getting wood scales, maybe one some synthetic (G10 or Micarta).
My question is how do you guys put together the handle scales if you etch the blade? If I finish and etch the blade, then glue on the scales (Acraglas) with pins, how do I go about not messing up the etch? I know there has to be a way...
One thing that comes to mind is to somehow shape the scales before they're attached permanently-never tried to do that before and not entirely certain the best way to go about it. But even so, there's still the epoxy problem. I also thought about sanding down the scales to match the tang (knowing the etch will be messed up)and then trying to somehow etch the tang with a q-tip or something, but that also seems to have some definite problems that could come up...
I may likely be over thinking things, but was hoping the folks here could set me straight. Thanks for any advice.
Jeremy
Jeremy
