- Nov 5, 2007
I used the blade of a good-quality scissors to start making my knife, and so far it seems good, however, the blade has a hole most of the way down where the other half of the scissors connected, but there's also an extended part about half the size that has a half of a hole in the side, um, if that's clear
somewhat like that:
______________
\_______o/---^-
the sharpened part is on the bottom, so any push on the bottom left in the upward direction would be countered by the handle on the other side while pivoting around the hole with a nail/copper wire pushed through it...
so what would be the best way to attach the handle? I was thinking that a solid handle with a slight groove where the blade would fit in, then the wire inserted through the hole to keep it there, with gobs of gorilla glue and string for the grip wrapped around... also, the layout creates the possibility of a folding knife, but I figured that'd be harder that heck, and I'd just leave it alone...
sorry for the rather scattered post, if you happened to get through it though... kudos to you
One other question, I only have a strop, so is there an easy way to sharpen the blade to the point where you could use the strop well, without having to actually go out and buy a sharpening stone?
Admiral
somewhat like that:
______________
\_______o/---^-
Admiral
