Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
I second the choice of 1084 in .125".
Ok so, im going with 1084, as it seems good! But Im going to stay at 3/16"thickness as I like a thicker blade.
Im going to purchase my blank this week and hopefully anneal it, and start cold work!
I don't understand your "blank"?
I thought you were getting a bar of steel and making the knife yourself. If you purchase a piece of steel from any of the knife suppliers, it will already be annealed.
By "cold work", do you mean filing and sanding? ( cold work means something else)
It is your knife, so suit yourself on the thickness, but you have to file all that excess steel away. Take it from a group of folks who have done this quite a few times, 1/8" is a hefty knife in a 3.25" blade. Your knife will cut less, and weigh more in 3/16".
you should choose circular sawblades for your steel
Wow, there is some really bad advice here. I'm surprised.
Congrats on your achievement!
(oh, and I'd go with 1/8" too.)
Do not use any electric grinder when working the grind of your knife, it could warp the blade.
I would reccomend going to your local scrapyard or a elder relatives garage and look for a old Nicholson bastard file. Then all you have to do is anneal it before working on it and use your oven and oil to temper it.
