Need a little help, please. I recently acquired a Buck Mantis. The knife is extremely hard to open, so, I thought Id loosen the pivot pin. When I put the torx to the pivot pin, the entire pin turns. (I dont have two torx bits
one for each side of the pin.) However, in turning the pin counterclockwise, even though both heads of the pin turn, the pin gets loose
so much so that when the blade is closed, I can grasp both heads of the pin and turn it with my hands
but not so loose that the pin offers to come apart. At this point the blade is easier to open. But if I keep turning the pin in the same direction, it goes from loose to very tight.
I cant understand why the pin would turn and get loose and then get tight. Am I about to mess something up?
What's the trick to doing this?
Thanks,
Van
Thanks,
Van
