- Aug 19, 2014
Im in the process of making 3 hunting knives for a co-worker. The blade steel is CPM 154 and Im going with amber stag with bolsters for handles. I want to use a stainless for the bolsters but Im not sure on what type would work best? Im considering using 416 but since its magnetic will it have the potential to corrode if it gets blood and other nasty fluids on it? Also, since 416 is heat treatable, should it be heat treated for bolsters and dose that have an effect on its corrosion resistance? I would think a 300 series stainless would work the best for corrosion resistance since its nonmagnetic but Im just not sure what the pros and cons are? I would and greatly appreciate any thoughts and insight into this. Thank you all in advance.
