- Nov 23, 2014
I'm making some Christmas presents and need some help with a folder. I'm making the knives with my step father who has made about 30 fixed blade knives but no folders. He usually just epoxies the pins in place then sands and finishes.
I'm making this knife from Texas Knife, http://www.texasknife.com/vcom/product_info.php?cPath=119_141_842&products_id=664
I'll be using the pin and thong to hold the spring mechanism, pin for the lock back pivot and pivot pin for the blade. I'm not going to be using the small scale reinforcement pins. Currently all we've done is rough cut the scales and epoxied them onto the respective sides. I dry fitted the knife before attaching the scales, its operated fine and locked well. I need help on the correct way to peen or otherwise set the pins in place, I assume without the aid of epoxy as this would really screw up the 2 pins that are used as pivots.
Thanks in advance.
Thanks in advance.
