Help with some not so scientific testing
I'm new to this hobby and just finished building my heat treat oven. I made a few blanks out of .118 AEB-L from Alpha. I made 6 small coupons (3/4 by 2"). I wrapped each in foil with paper and heat treated to different temperatures for 6 minutes. I then broke the coupons, filed and hacksaw tested to see how hard they felt. I then put the remainder of the coupon in a dry ice bath for a couple hours and refiled and hacksawed with the following results. Each hacksaw test was 20 strokes.
I'm really hoping that someone more experienced could have a look and help me with what I should be aiming for as this is somewhat subjective. Here's my results. Sorry if the photos are a little blurry. The best I could do with my phone. There was a very noticeable difference after the sub zero.
Please note that each photo is at each temperature. The pre freeze is left and post freeze is right.
1955 Degrees - Pre Freeze - Very fine dull grain structure, could slightly grind with a file. The hacksaw cut in about 1/8".
Post Freeze - very fine dull grain structure, file just shined up the edges, hacksaw just barely indented the the corner, couldn't cut.
dateposted-public
dateposted-public
1965 Degrees - Pre Freeze - Fine grain, some shine, less dull, Hacksaw cut in about 1/16th
Post Freeze - same grain, tough getting the hacksaw to start, very little rounding of the corner.
dateposted-public
dateposted-public
1975 Degrees - Pre Freeze - Little courser but look very similar to 1965. Still mostly dull with some sparkle. Hacksaw cut in about 1/32
Post freeze - Gran looked the same, hacksaw didn't do anything
dateposted-public
dateposted-public
1985 - Pre Freeze - Grain is getting courser, About 50% shiny, 50% dull, hacksaw wouldnt touch it
Post freeze - same grain, very hard, file and hack saw had no effect
dateposted-public
dateposted-public
1995 - Pre freeze - Gran is course and shiny. very hard, no effect with file or hacksaw
Post freeze - same as above, can't test hardness
dateposted-public
dateposted-public
2000 -Pre freeze - Gran is course and shiny. very hard, ne effect with file or hacksaw
dateposted-public
dateposted-public
The subzero step is pretty much a requirement for AEB-L to hit proper hardness and combat retained austenite. What I find strange is your grain structures. I have to wonder if maybe you’re temp is off or something. I am running mine at 1975 plus cryo and snapping them to find grain finer than any of the pictures here. Personally I would call everything but the first one fairly course, especially for this steel.
That's the input I was hoping to get. I may be too hot.
I don't know why but when I look at my post I don't see the pictures, just the img symbol.
I’m not seeing the pictures either just image tags but I can click on them and open them.
Scott basic members need to use something like imgur to host the pictures before posting
I would also say those look to have rather large grain. Here is a D2 sample I tested and this is under 30x magnification. You should not be able to see the individual grains with your eyes.
Try lower temps, like 1925 and maybe 1940. Try to find someone to do actual hardness testing instead of filing/sawing.
Thanks for the help guys. I tried setting an off set on my pid by checking for non magnetic but it looks like I missed the mark by a big margin.
I appreciate the input.
