I am wanting to make a set of Bowie knives for myself using the antlers from a mule deer that I got last year. It's my first buck so I wanted do do something with it and being a knifmaker I figured making knives with it is more meaningful than mounting it. They will be primarily an art knife with fancy furnishings on it but I still want it to be very strong and fully functional. The issue I am having is that the antlers have a slight curve to them and I'm not sure of the best way to design the tang because of this. I also want to put a thin but cap on end of the handle. I've seen makers weld or solder a threaded rod to the tang and a matching nit to the butcap so that they screw together but I don know if you can do that with a curve in the material. I've also seen some people cut grooves into the tang for the epoxy to grab and some say you really don't even need a pin then. Basically my biggest concern is will a tang that runs about two thirds through the handle be enough to support a large Bowie knife and if not what are my options. I put a picture in to show my design so far. i am planning to do a small pin in the centre of the handle.
