It''s the same as the current INFI chemical formula, not the same as the formula from decades back. It has changed.“Better” is subjective, depending upon your use case. As Jerry has explained, the chemical formulation of the steel is exactly the same as the regular INFI we’ve all come to know and love over the decades. The only difference with INFI-XC is the heat treat protocol which has been modified to enhance edge retention at the expense of absolute toughness and impact resistance. You can let your penchant for abusing blades be your guide as to which flavor will best meet your needs.
I suspect a lot of folks, particularly those purchasing blades on the shorter end of the Busse spectrum, are going to become quite fond of INFI-XC.
So, is the model that is available on line the XC heat treat protocol?
“INFI-XC is not a change in INFI's composition or constituents. It is simply a change in our heat-treat protocol.”
Yeah, without XC, the next time you need to cut 3,000 sections of 1” hemp rope, you’d be taking a huge chance you might have to resharpen before the job was done. Good thing you checked!
Yep, right there with you. (You thought I was joking?)
