Soooo I have my blade profiled...handle needs some more attention but I figured I would grind the blade first.
I sill be using a grinding jig for the bulk of it...and a file jig to hopefully finish it perfect.
What size hole is standard for the tang...and whats a good source for brass rod?
Its my understanding that you dont fully sharpen the blade until after heat treat.
What thickness am I shooting for before heat treat. Am using 3/16 1095 and a flat grind if that matters.
What grit should I use for the final grind??
If a fella had to pick between hardwood charcoal and a cutting torch for heat treat.....is one better than the other as far as decarborizing??
Seems like I had another question but I cant think of it at the moment.
TIA
TIA
