Here's A Pic Of The Buffalo Soldier !
Jerry Busse :
Jungle coating
I seen nothing "jungle" about that coating. I sent a picture of that blade to a friend of mine who lives in the jungle, and he is confident that the blade coating represents no "jungle" he is familiar with. I also live in a very rural area, not a jungle, climate is more northern, however there is no vegetation which resembles that coating. In particular it is much too thin and hard.
The term also impies that the blade could be used as some kind of clothing. Now I only went to grade three (took seven years, grade two was HARD), so I might be wrong here (even though I am currently attending law school, and have worked as a security guard for the louvre while being a body guard for the pope on the side), but I don't see how that blade could be used as any type of clothing. It would have very little insulative value. You should put a disclaimer on the label to insure that people are not mislead by your imprecise wording.
In addition, this blade length is all wrong for "jungle" survival. I know knifemakers who primarily supply blades to people living in such enviroments and while the stock thickness is sensible, the blade is much too short for brush use and thus any use of the "jungle" label is just misleading. I think the use of the term is very misleading and such labels show nothing but a lack of self confidence. And the blade steel is much too hard I would bet that you can not sharpen it very well on a cement block.
As well the use of all black blades is personally offensive. It is racist to the extreme. There are no blades of colors in your lineup which corrospond to the skin tones of the other currently existing races. If you don't address this issue immediately I will be forced to take legal action which can include up to assault by artic seal teams and northern cod.
-Brad Pitt
The desert coating looks a lot like my skin! I'm a little darker, but we both have that strange, stipled effect.
The green coating only looks like my skin when I get angry. You wouldn't like me when I'm angry....
;) :D
Or Fight Club.
On a semi-serious note, the comments about axes and chopping are based on tasks which the current chopping knives are not used for. It would be like using the recommendations of knives used to butcher whales to defend the arguement of fillet knives for trout.
Most people using knives for chopping wood in a survival situation are cutting very small wood. You don't knock down a 12" tree (which is several hundred pounds) to build a lean-to, or start a fire. This is all done with very small wood, even four inches is at the upper limit and not necessary even for a small cabin. There is a group of kinds actually building a log cabin on one of the lots I am currently clearing (all family), and the sticks they are using are all very small. Makes ease of construction very high, try carrying around 6-8" thick logs, with people complaining about the weight of a 10" bowie on their hip, I don't imagine a several hundred pound tree would be too comfortable. Now set it up and hold it in place for construction purposes, now consider dropping it, fall or otherwise lose control and see the relative danger. Having working cutting wood for many years this will happen, and it only takes once to kill you. In an emergency situation working with that wood ouside of the absolutely necessary screams "rambo delerium" to me much more so than a nice long knife.
As well consider injury, doing some really stupid recently I strained one of the tendons in my right leg. It really bothers me now to put any weight on it, trying to carry a tree of any size would be near impossible. As well trying to swing an axe two handed would not be functional as well. However I can still readily use a small saw and large blade to cut down small trees, section them into lenghts and work on other such materials. Not to mention the other advantages of long blades such as cutting light vegetation for construction, food, bedding and clothing. Trail clearing is rare here, but also has value in certain certain situations.
That being said, I have many axes and use them all for various tasks, including "field work". In very cold weather axes have a large advantage over most knives due to the ability to cut holes in ice, but a khukuri can do that very well also. Long blades also are much nicer to work with for snow based shelters than axes which are then next to useless for cutting and shaping blocks. As for history of use, many heavily chopping natives, and other "experts" can be found to endorse blades, and very thick ones as well. Just look around and remove the focus off one particlar viewpoint. You will find very thick khukuris, long and thick parangs, bolos and all variety of blades used for wood working.
Back to axes and wood chopping, saws replaced axes almost instantly as well for bucking and felling. They are much more efficient, much safer and the edge retention is much higher. They are somewhat more limited in use though, but aside from felling and bucking, a nice folding saw comes in very handy for construction, both shelter building and trap and tool making. The ability to quicky cut neat notches is very nice. This is one of the reasons I like a quality SAK. The decent sized large blade and saw will allow easily cutting of shelter sized wood and is very versatile (change the large screwdriver into a chisel and you have a very nice tool). I carry other folding saws when possible though as the SAK saw is a little short. I have a folding swede saw (almost full size) in the trunk of the car, other folding saws in the glove compartment and on me if I am wearing a heavy coat.
I would currently carry for extended woods work something like :
1) quality saw for bucking, felling and notching. I like japanese saws, but still don't trust my skill level yet not to break them in times of high stress or impaired mental state which is why I would prefer a quality swede saw in an emergency.
2) small blade for any carving and other precision work, a decent SAK is really nice, I like a nice narrow blade as it makes turning much easier, the bandicoot would be nice, but there are lots of other great blades here like the Temperance from Spyderco, Deerhunter from Russell, almost anything from Boye, etc. . A wider blade like the Howling Rat does does offer a more versatile grip on the blade, and I would not be put off depending on that either.
3) long blade for limbing and other brush clearing and waste removal when felling, and bucking of semi-soft woods, or all woods depending on physical state. Still looking for the ideal one of these have tried a lot. Definately plan on picking up a MOAB later on, and waiting for Swamp Rat to get a decent long blade in the line.
For most EDC I would carry a much finer knife for most cutting, the new D2 Swamp Rat line looks to be a solid choice, and a more pry bar class knife like the Camp Tramp for rougher utility work (that would be a nice addition to the above three for woods work in regards to scavenging materials usually).
Fine looking blade by the way Jerry.
-Cliff
Originally posted by Cliff Stamp
Jerry Busse :
-Brad Pitt
Mr. Pitt,
I disagree. Just as the "desert coat" is similar in texture to actual sand, I have reports that the "jungle coat" has a texture not unlike that of Black Palm... commonly found in the jungles of Panama.
HTH:cool:
Well, looks like Jerry was infringing on my Cobalt Green knife coating patent. Hmmm. I see a lawsuit in my future. Ok, send me one and I'll forget all about it:mad:
Been there tried that....he didn't fall for the "Dark Nemesis Sasquatch Hunter Green Coating" patent :grumpy:
Nope... but he did buy off on the "SpearHead Moose Hunting Bear Skin Loin Cloth Wearing Muskeg Green Coat". And he paid handsomely for it.:p
No Regrets! :D
So, now you stole my idea also, huh. What knives have you got for reparations???:rolleyes:
Spearhead, I'm calling and canceling my ten jungle knives tomorrow....yuck!!!!! :)
Cobalt...reparations? Hmmmm, I've got a nice machete...got a lot of scratches but it's yours to settle the bill :D
CHUCK!!!!!
Hell man, do you see this?!?:confused: I've coveted your machete but I've never tried to give it away... Shameful.:D
GREAT an INFI Machete, man, it will be my first. Thanks man, I thought I was going to get some little blade, but a Busse INFI machete. Your alright in my book. I'll email you my address.:p
No problem my friend....but email Jerry you info. That thing's been boxed up sitting in a corner without a shipping label for almost eight months. I'm sure he'll be glad to get rid of that thing tomorrow :D
Shiieeaat, that guy, I'll never see the machete, i'm still waiting for my Fussia SH to arrive:eek:
Wow, this knife looks like it would make a great hunting knife.:D Hope Jerry makes some more.
