Here's the handle I put on QL's khukuri.
And the frog I made from 9-10 oz leather.
>>>>---¥vsa---->®
"Know your own bone, gnaw at it, bury it, unearth it again."
'Thoreau'
Khukuri FAQ
[This message has been edited by Yvsa (edited 03-17-2000).]
So THAT is what four of the blocks of wood you sent me turn out tot look like. Enough to handle a 12", 15" and 20" Sirupati and their kardas and chakmas with. Oooooooooooh.
Ever since I received that non-khuk thing you and your cuz did I'd been wondering where to put you. Bura does more technically accomplished work, Sanu does stuff with strong spirit all his own, and now I can only think of you, Yvsa, along with the title of the Isaac Asimov book "The Sensuous Dirty Old Man": it just takes one look at your work to tell what was on your mind. That's a compliment, son. And good natured Tzn. Excellent lines.
Wow! I especially like the handles on the karda and chakma -- they look like you could really get a grip on them. I wonder what the kamis would think if they saw them. Let's try to get a picture to them ... or better yet, some examples....
-Cougar :{)
Nice Work Yvsa! Really, that's some beautiful woodwork there. I'd be proud to own a Khuk. handled thataway. Rusty, I honestly don't know what you are talking about, but that's probably cause you must be referring to an inside joke between you and Yvsa? Anyway, nice work.
Rob
You keep doing fine work like that and uncle Bill may send you over to Nepal. That stuff is Really damn fine work.
YVSA,
What a beautiful job!
It's interesting that you made the handles on the chakma and karda so free flowing.
On many of the very old khukuris you will find the small knives handled with uniquely shaped or spurred pieces of bone and horn, not symetrical like we are used to seeing.
Very impressive and well done. For what it's worth, I'm blown away.
JP
Oooowweeee! "'Em's sum purty handles!" I sure would like to hold those in my hands!!! The next time you're in Alabama, stop by for a little while, I'll feed you well and let you do a little of this kind of work for me! What kind of wood is that? Any chance of getting a blow-by-blow description of the process involved? (Macining, hand-shaping, etc.) Incredible work Yvsa! Keep it up
Rob
Nothing soothes the nerves like a sharp knife in hand...
Imagine how my day turned out when this arrived in the mail!! I am still grinning about this one - guess I had better go oil it again, it has been about 24 hours since the last application... Thanks again Y, you are quite a craftsman.
Cheers for now,
QL.
MauiRob: Some time back I had one of the first villagers brought in, and was in the process of putting an elk stag handle on it and reshaping blade and handle to full forward curving. Something made my short of breath and I sent the blade to Yvsa. He said he had a chunk of wood to cut up for handles and would send me some. Now I see what that looks like finished.
As for the book reference, 20 years ago there was a series of books coming out "The Sensuous Woman" "The Sensuous Man" "The Sensuous Couple" ad nauseum. OK? Well one of the trinity of 50's thru 70's science fiction writers: Isaac Asimov, ( the others were Arthur C. Clark & Robert A. Heinlein ) decided to do a spoof of the "sensuous" subject, coming out with one called "The Sensuous Dirty Old Man"
Remember the phrase about "In spring a young man's fancy lightly turns to thoughts of love" or similar drivel.
Asimov's version went, if I remember correctly: "In spring a young man's fancy lightly turns to thoughts of what, the older man throughout the year, has never even once forgot."
In other words, to build such a sexy handle he must be a very dirty minded old indin.
( Look at Yvsa's response to my comment on his full forward curving khukuri and you'll see both he and I both note that particular bladeshape to be reminiscent of a certain attribute of the other gender. )
Now to post this before my common sense returns.
[This message has been edited by Rusty (edited 03-18-2000).]
So wonderful. Great job, Yvsa. I will make the top pic my Windows wallpaper. Hope you don't mind.
OH CRAP!!!!!!!! Yvsa, that is honestly one of the best pieces of work I've ever seen! We really should send a pic of this to the kamis.
- D
That is really nice work Yvsa.
How did you attatch the handle? What did you put underneath the brass bolster?
If anyone is interested a oz/sq.ft of leather is about 1/64" thick. The thickness that Yvsa is using is equavlent to belt leather.
Will
Thanks guys!!!
High praise indeed from John!!
I was really pleased wth he way it turned out.
Rusty has 2 of the failures that will still make handles for smaller khukuris.
The only power tools involved was a hand drill and a buffer on my bench grinder, and a dremel tool that's really a Ryobi.
I will be able to do more extensive work now as time permits due to the new Grizzly buffer and belt knife grinder.
At 1725 rpm and 3,600 sfm on the belt it will make short work of reshaping and sharpening. The buffer will help even more with the finish work.
The belt knife grinder also has the motor shaft (1 hp.) running all the way through the motor which allows a buffing wheel to be attached to the side opposite the belt.
That will allow me to have 3 buffing wheels on at one time giving a rough, medium and finish wheels.
The wood is one of the Cherokee's old time bow woods and is Honey Locust.
The 1st. two tries resulted in handles too small in some place or the other making them unfit for this application.
The chakma and karda handles were a bit of trouble also as I would get one down to the final stages and find a crack starting to develop into failure. It's a bear trying to use a dremel to cut the wood away for the little tangs to fit into.
I used a wood burner to burn the decorative angles into the wood.
I use a caliper that I used to scribe lines in steel when I was laying out cams for auto screw machines. The one point is standard with a rounded point and the other I sharpened flat and sharp to mark the steel with a crisp line. It makes it easy to keep the edges of the lines even with the first one put on.
Will, I try to get as much wood as possible under the bolster. This one came within about 3/16" of an inch (5 to 5.5 mm) and the bolster has just enough clearance to permit epoxy between the sides of the brass and wood. The kamis have an easier time of it since they are fitting the bolsters to the handle instead of the opposite.
I use 30 minute 2 ton epoxy to set the handles. I would and will use the 24 hour if I can ever find it.
TD, I don't know what the "wallpaper" is but you're welcome to use the pic. Glad you like it.
I learned a lot from this opportunity since this is the first one I have actually totally redone. The other ones I have had the oportunity to work on all had good handles.
It took me 3 tries to get ech handle right. I would never send anything I make out to
anyone that I wouldn't be proud to keep myself. Sometimes the quality of the materail itself ( forgeing cracks, holes in the steel and similar) prevents that, but not often
Did everyone notice the sheen on the scabbard and knives?
I used Johnsons Paste floor wax on everything. It helps to prevent fingerprints and also any corrosion.
I really like the wax for showpieces. I wouldn't use it on anything I take into the field as it shines too much for me. I prefer Not to be seen when I am in the woods.
>>>>---¥vsa---->®
'Thoreau'
Khukuri FAQ
Honey Locust. That's what I'd been meaning to ask, and why you threw the unfinished handles in with the rest of the wood.
Again, beautiful work.
