- Jan 31, 2009
Yep, ive got that one :thumbup: and ive never gotten sick drinking water my MSR filtered.
For use in the Mideast, and elsewhere where viruses ARE an issue, you should chemically treat the water after filtering.
And if you don't like the chemical taste, you can get an in-line carbon filter for your hydration pack.
I believe he was suggesting that a carbon filter would remove the taste of the chlorine or iodine that killed the viruses.
Maybe I am just a little different, but I don't use filters. Take up too much space.
Big ole jugs of Clorox Bleach last me a very long time for around $1 per jug on sale.If I really don't trust it I'll boil it too. As far as clunky water filters? No thanks.
Yes, I should have been more clear. I believe Camelbak sells one such carbon filter.
I have seen in-line purification filters for hydration packs available too, but they may be difficult to drink from.
As long as you realize that bleach is ineffective against Giardia and Cryptosporidium.
How bad is Giardia? I knew a guy who was a ranger at Philmont who got it. I don't recall what the symptoms/effects were. But nothing that couldn't be cured. Anybody had Giardia or Cryptospridium?
Reason I ask is I would like to be covered against the most serious water born contaminants without going bananas. In other words I would like to stick to two sanitizing/cleaning methods, but preferably one! So far I'm leaning towards UV and Filter. If I wanted go nutty I could add bleach or boiling. But IMO I don't want to be doing all that to take a sip of water on the trail!
Giardiasis - Symptoms
Abdominal pain
Diarrhea
Gas or bloating
Headache
Loss of appetite
Low-grade fever
Nausea
Swollen or distended abdomen
Vomiting
The time between being infected and developing symptoms is 7 - 14 days. The acute phase lasts 2 - 4 weeks.
Cryptosporidium Infection Symptoms
By Mayo Clinic staff
The first signs and symptoms usually appear two to seven days after infection with cryptosporidium and may include:
* Watery diarrhea
* Dehydration
* Weight loss
* Stomach cramps or pain
* Fever
* Nausea
* Vomiting
Symptoms may last for up to two weeks, though they may come and go sporadically for up to a month, even in people with healthy immune systems. Some people with cryptosporidium infection may have no symptoms.
The thing is, what is unpleasant and time off from work when you are " at home" can be life-threatening if it hits in true wilderness.
Think I'll stick with the UV and the filter! Unlikely I would get either, but its only an extra 60-90 seconds to hit the water with UV.
Can anybody recommend a good gravity fed filter? I was looking at a Platypus Gravity Works, it weighs about the same as my Katadyn Hiker and works faster (with no pumping!)
The Platypus Clean Stream is my favorite. There is a bag labeled "Clean" and another labeled "Dirty." Can't get much easier than that. It uses the hollow fiber filter technology though, so it will not do chemicals. If you want one that can reduce chemicals with activated carbon, try the Katadyn Base Camp. It is slower and does not have the extra reservoir, so there is a bit of a trade off.
