Hex Wasp Red Dot / Holsters: Glock 26, M&P9c, Nano / Flashlights *11/23 price update*
Feedback: +95 / =0 / -0
Sale Terms:
  • US shipping only
  • First Class shipping unless otherwise noted
  • Paypal Purchase of Goods Option (no gift payments please)
  • I reserve the right to refuse sale at my discretion
  • No trades/No Proxy Buying
1) Springfield Armory Hex Wasp Micro Reflex 3.5MOA $175 ships priority $190
2) Glock 26: Axis Elite (AIWB) $65 $70
3) Glock 26: Tier1 Xiphos V2 with Ulti Clips (AIWB) $40 $45
8) Thrunite T10vn II, SBT90 5700L De-Lens modified by Vinhnguyen54 $55 $60
9) Convoy M2vn Oslon W2 modified by Vinhnguyen54 $45 $50
10) Mateminco TK01vn NW XHP 50.2 modified by Vinhnguyen54 $50 $55
11) Amutorch vg10vn SBT90 5700L De-Lens modified by Vinhnguyen54 $55 $60
Free based on timestamp (also listed on TexasGunTalk)
4) Glock 26: Tulster Holster [Claimed by KnifeCollectorPB] Free
5) S&W M&P9c: PJ Holster IWB Kydex Holster Free
6) S&W M&P9c: Tulster Holster Free
7) Beretta Nano: PJ Holster Tuckable IWB Kydex Holster Free
12) Kahr CM9/PM9: PJ Holster Tuckable IWB Kydex Holster (unpictured) Free
Red Dot. 3.5 MOA Dot with approximately 65,000 hrs battery life, brightness auto adjusts with sensor. Includes mounting and adjustment tools, battery, and instruction manual. No box is included as this came with a Springfield Hellcat RDP in which a Holosun 407K was mounted instead.
Never mounted or used, only handled for photos.
Features:
· 5 MOA (90 MOA Windage & Elevation)
· Glass, Scratch Resistant & Anti-Glare Coating
· FOOTPRINT: Springfield Micro, Shield RMSc
· Always On
· Machined 6061 T6 Hardcoat Aluminum
· WIDTH 0.95" LENGTH 1.60" HEIGHT 0.86"
I carried with this holster a couple of times but found I prefer the smaller profile of the Xiphos V2 and carrying a spare mag separately. Sells for $135 plus shipping on Tier1's page.
Weapon Light Compatible?: No
Gun Make: Glock Glock Model: 26 Gen 2-4
Dominant Hand: Right
Color: EMT Red
Sweat Guard: Mid
Threaded Barrel: Yes
Belt Clip Style: Standard 5 Hole
Extended Spare Magazine?: Yes
Shock Cord Color: Black
Have carried with this a number of times when working out. Minimal wear, FrogLube was applied to retention screw to prevent rust after incident was first observed on above holster. Sells for $89 plus shipping on Tier1's page.
Weapon Light Model*: None
Color: EMT Red
Sweat Guard: Mid
Optic Cut: Yes
Suppressor Height Sights: No
Threaded Barrel: No
Upgrade to UltiClips?: Yes
Carried with a number of times.
Handiness: Right Handed.
Belt Width: 1.5"
Adjustable Cant: 0-30 Degrees
Tuckable: No
Carried with a handful of times.
Belt Width: 1.25"
Belt Attachment Type: Over the belt clip on Loop (clip reinforced/thicker than standard)
Kydex Thickness: 0.80"
Holster Cant: 15 Degrees
Tuckable: No
Belt Width: 1.5"
Tuckable: No
Checked for fitment but never carried.
Belt Width: 1.25" (I can get this over a1.5" belt)
Tuckable: Yes (shirt can be tucked while conceal carrying)
Emitter: Luminus SBT-90. CW Tint with great output for it's size. Uses DriverVNX2 Programmable Driver/UI. Includes box/tin, high drain 14500 battery and accessories.
Emitter: OSRAM OSLON White2 (6500K cool white). This was modified by Vinhnguyen54 @ CPF and direct from him. Strike bezel was heat treated and Vinh added his FS54 forward clicky switch. Uses the programmable VN4 firmware. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes a high drain 18650 battery, and grip ring. Nice clean and white beam with good throw. Approximately 1000 lumens.
Emitter: Cree XHP 50.2. Tank of a light with a nice 4000K tint and Stock UI (moonlight, low, medium, high, turbo). Includes an 18650 battery spacer, lanyard, protected 21700 Acebeam battery, and box. Full disclosure: The charging connector moved inward for some reason so a micro usb will no longer make contact. A 21700 battery can still be charged outside of the light in a charger in a separate charger (not included).
Emitter: Luminus SBT-90. CW Tint with great output and throw for it's size. Uses DriverVN4 Programmable Driver/UI. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes 21700 battery.
The following are all free (1st come, 1st serve). Keep in mind these are available at TexasGunTalk as well so timestamp will be tiebreaker should the same item be requested. Happy Thanksgiving!!
4) Glock 26: Tulster Holster Free
