From Wiki:
The Janka hardness test measures the hardness of wood. It involves measuring the force required to embed an 11.28 mm (0.444 in) steel ball into wood to half its diameter. This method was chosen so that the result would leave an indention 100 mm² (0.16 sq in) in size. It is one of the best measures of the ability of a wood species to withstand denting and wear. It is also a good indicator of how hard a species is to saw or nail.
The hardness of wood usually varies with the direction of the wood grain. If testing is done on the surface of a plank, perpendicular to the grain, the test is said to be of "side hardness." Testing the cut surface of a stump would be called a test of "end hardness."
The results are stated in various ways, which can lead to confusion, especially when the name of the actual units employed is often not attached. In the United States, the measurement is in pounds-force (lbf). In Sweden it is in kilograms-force (kgf), and in Australia, either in newtons (N) or kilonewtons (kN). Sometimes the results are treated as units, e.g., "660 Janka".
To convert the United States pound-force (lbf) units to newtons N multiply pound-force by 0.453 592 37 then multiply by 9.80665 (1 standard g in units of m/s2). Janka hardness N = (lbf x 0.453 592 37) x 9.80665 OR multiply by 4.44822161526. To get lbf from N, multiply N by 0.224808943099736.
A common use of Janka hardness ratings is to determine whether a species is suitable for use as flooring.
The Janka Hardness test below is done in accordance with ASTM D 1037-7 testing methods. Please note, no flooring is ever tested. The test is done on raw material stock that can range from 1" to 2" thick. Note these numbers are an average! A standard deviation exists for each species, but these numbers do not get published. The chart is not an absolute; it is meant to help you understand which woods are harder than others. There are other factors that can affect how flooring performs: type of core (for engineered flooring), grain direction and thickness floor or top wear surface.
The "Hardness" Testing for Wood is very similar to the common hardness testing for steel.
For steel, they also "Indent" the steel to measure hardness for Rockwell, Vickers, and Brinell hardness testing.
Like steel, I think it is worthy to point out that "Hardness" is not the same as toughness. However, in regards to chopping on a given type of wood, that hardness can very much be "Felt" and a test on the knife and chopper.
Wood Flooring Species Janka Hardness (pounds-force)
4500 - Lignum vitae / Guayacan / Pockenholz
3692 - Brazilian Ebony
3684 - Ipê / "Brazilian Walnut" / Lapacho
3680 - African Pearlwood / Moabi
3650 - Bolivian Cherry
3640 - Lapacho
3540 - Cumaru / "Brazilian Teak" sometimes: "Brazilian Chestnut," "Tiete Chestnut," "South American Chestnut," "Southern Chestnut"
3220 - Ebony
3190 - Brazilian Redwood / Paraju / Massaranduba
3040 - Yvyraro
2900 - Bloodwood
2697 - Red Mahogany, Turpentine
2670 - "Southern Chestnut"
2473 - Spotted Gum
2350 - Brazilian Cherry / Jatoba
2345 - Mesquite
2330 - "Golden Teak"
2200 - Santos Mahogany, Bocote, Cabreuva
2170 - Pradoo
2160 - Brazilian Koa
2140 - Sucupira sometimes "Brazilian Chestnut," "Brazilian Walnut"
2135 - Brushbox
2030 - Karri
2023 - Sydney Blue Gum
1980 - Bubinga
1940 - Cameron
1933 - Tallowwood
1925 - Merbau
1912 - Amendoim
1910 - Jarrah
1860 - Purpleheart
1850 - Goncalo Alves / Tigerwood
1820 - Hickory / Pecan, Satinwood
1810 - Afzelia / Doussie
1798 - Bangkirai
1780 - Rosewood
1725 - African Padauk
1720 - Blackwood
1712 - Merbau
1710 - Kempas
1700 - Black Locust
1686 - Highland Beech
1630 - Wenge, Red Pine
1624 - Tualang
1575 - Zebrawood
1570 - True Pine, Timborana
1557 - Peroba
1540 - Kambala
1510 - Sapele / Sapelli
1490 - Curupixa
1470 - Sweet Birch
1450 - Hard Maple / Sugar Maple
1390 - Caribbean Walnut
1390 - Coffee Bean
1380 - Natural Bamboo (represents one species)
1375 - Australian Cypress
1360 - White Oak
1350 - Tasmanian Oak
1349 - Ribbon Gum
1320 - Ash (White)
1300 - American Beech
1290 - Red Oak (Northern)
1280 - Caribbean Heart Pine
1260 - Yellow Birch, Iroko Kambala
1230 - Movingui
1225 - Heart Pine
1220 - "Brazilian Mesquite" / Carapa Guianensis
1200 - Larch
1180 - Carbonized Bamboo (represents one species)
1150 - Teak
1136 - Cocobolo
1125 - Brazilian Eucalyptus / Rose Gum
1100 - Makore
1100 - Siberian larch
1080 - Peruvian Walnut
1023 - Boreal
1010 - Black Walnut/North American Walnut
1000 - Teak
995 - Sakura
950 - Black Cherry, Imbuia
940 - Boire
910 - Paper Birch
900 - Cedar
870 - Southern Yellow Pine (Longleaf)
840 - Lacewood, Leopardwood
830 - African Mahogany
800 - Mahogany, Honduran Mahogany
780 - Parana
770 - Sycamore
710 - Shedua
690 - Southern Yellow Pine (Loblolly and Shortleaf)
660 - Douglas Fir
590 - Alder (Red)
590 - Larch
540 - Chestnut
500 - Hemlock
420 - White Pine[disambiguation needed]
410 - Basswood
380 - Eastern White Pine
100 - Balsa
