You're the machinest.
I just started to try using my HF table top surface grinder. It won the battle yesterday. Any pointers on getting a smooth (and even) finish? ...getting a tight tolerance?
Also I'm using one of those $100 single pole mag chucks and find that my pieces will slide around on it and the edges will pull up from heat. Is this normal? Do I need a better/stronger chuck?
What I've figured out so far, tell me if I'm right or wrong on any of this:
I can only take .0025 off at a swipe. This unit is only 1/2 HP.
I can only take .010 to .030 lateral swipes before I start getting a real noticeable cupping.
I have to move the wheel damn slow, much slower than I thought I would have to get a smooth finish.
I have to keep the metal cool enough to touch, I'm spraying it with wd-40 (it was there) and that helps but I'm thinking there must be something better.
I'll just doing small pieces if I want any accuracy (ie folder parts).
I've looked in my machinest books, none have practical operations of a surface grinder. Any help would be appreciated.
