Thanks again Hoss. My apologies if I asked too many questions. I really appreciate you took the time to answer.
All the best,
Constantin
You’re welcome.
Hoss
All the best,
Constantin
Grains of steel look like soap bubbles in a jar. During grain growth, grains eat each other becoming larger. Carbides occur within the grain and at the grain boundaries.
Within similar carbide volumes, the smaller the carbides, the more of them you have and the more evenly distributed they are. The more carbides you have, grains will have a hard time growing because they are bumping up against the carbides, or pinning the grain boundaries.
Pearlite occurs mostly in simple or low alloy steels. Under a microscope, pearlite looks like very fine lamellar carbides in between ferrite, they are much finer than normal carbides. The finer the pearlite, the finer the grain when heat treated.
The finer the spheroidite or the finer the pearlite, the finer the grain in the final heat treated piece.
Hoss
Out of curiosity, would you recommend hardening from fine spheroidite or pearlite if going for controlled hamon formation with clay? I've had good experience with both methods on 1095 and have not yet tried spheroidite with my W2 (just forge, normalize and down cycle, grind/clay/quench).
Thanks for all your previous posts, informative as always.
Also aware of the insane amount of variables in hamon formation, just curious about your preferred state to harden from when shooting for one.
-Trey
Fine pearlite or fine spheroidized condition is what I use when going for a hamon. If doing a longer soak, martensite is fine too. You just want the get hot enough long enough that the martensite under the clay converts to austenite when heating.
I'm more interested in Jamon than Hamon !
The most beautiful hamon structures are those made by traditional polished by hand types !
'Refining grain' - the only way you'll be refining grain size is to create new grains ! However heat and time can grow existing grains. That's why I said work on grains first , carbides later,
I was unable to do a hamon on W2 without it touching the edge until I switched to a drum forge from kiln.
I think you're right where soak time is a bigger factor than previous steel state as long as it is in a good hard enable state (fine pearlite/spheroidite)
Thanks for the insight everyone
-Trey
I was unable to fully harden it in my kiln without going over because my kiln had an uneven heat spread. My drum holds a more consistent and even heat so all my heat treat in general is much better now. My kiln had a heat trap in the end that cause a large temperature gap between front and back of oven.I have no trouble with the kiln. It took a lot of trial and error to get the clay thickness, steel geometry, soak times, and quenches “right”, as if there is a “right.” If I went to a forge, I’d have to figure out the process again. I do go for an optimum performing blade, rather than heat treating for the best hamon, which can be at odds each other.
