I did a search and came up with some info, but that only left me with more questions, so here goes....I am attempting my first hidden tang knife. It is ATS-34. I left about a 2" stub to weld the threaded rod to. I believe Tom suggested slotting the stub and welding/brazing a grade 8 bolt in. Now my questions. Do you weld or braze? What do you use for a heat sink? Can you suspend the blade in water up to the point that you don't want the heat to spread past? I have access to TIG, MIG, stick, and brazing equipment, which is best for ATS? What type of rod/wire do you use? My appologies for all the questions, but I would rather ask than ruin a blade.
Thanks in advance.
Thanks
Leonard
http://albums.photopoint.com/j/AlbumIndex?u=875252&a=6373014
Thanks in advance.
Thanks
Leonard
