- Oct 27, 2005
I have a question about slotting the handle material for a hidden tang knife. I'll begin with how I'm currently doing it, but it is a PITA the way I'm doing it. There must be a better way.
Currently, I make the guard first, and slot it with drills and files until I get a nice fit up to the ricasso. I use a file guide and hand file the slot in the guard and the tang of the knife, including the back of the ricasso.
I then use stick glue to glue my guard onto the partially shaped handle material. Once the stick glue is set up, I use the guard as a template and drill the handle material. My problem is that the sides of a drill bit don't cut, so it's a pain to get a uniform slot all the way down.
I usually use a single pin through the handle and tang to secure everything.
Can I get a long shafted end mill that I can put in my drill press to clean out this slot? If I can get one, where would I find one at?
How do those of you who slot handles and guards perform this procedure?
Ickie
Ickie
