While high carbide content stainless steels are great for folders and general purpose knives that are going to see abrasive materials, kitchen knives are going to encounter much different and softer materials. I've cut more vegetables and proteins than I have pretty much anything else. For these type of materials you want a thin, hard, and easy to sharpen edge--which is why carbon steels still dominate higher end kitchen cutlery. Their lack of corrosion resistance, though, can be off putting for some people.
I've gone from using stainless (VG-10) towards more carbon steels in the kitchen. The edges last longer, don't chip as much, and are stable even at very thin geometries.
Here are my most used knives:
I see lots of Konosuke love in this thread. The gyuto above is a funayuki profiled HD2.
You do have to learn to religiously clean and dry these types of knives right away. If some spots feel a bit rough (such as what can happen if you leave onion or tomato juice on for extended periods, or leave the knife to rust in a humid environment for weeks at a time) then invest in some automotive 1000 grit sandpaper and shine-up the blade every now and again. With enough rubbing you can make any old carbon blade look just like new.I recently bought Wusthof's 200th anniversary set, and 8 inch chef's and a parer. The knives are purportedly made "the old way" and are of high carbon steel. I've used the chef's knife (pictured) maybe 6 times, on basic veggies and some proteins, and I've washed and dried it fairly quickly after each use. There's quite a patina already developing, although I can feel the dark spots on the blade when I'm drying the knife, or just running a fingertip over the discolored areas. As soon as I got the knives, before use, I rubbed then down with the supplied Barristol oil, and I really have tried to be careful, much more so than with any other knives I've owned, but the "patina" is happening alarmingly quickly. The worst damage (the darkest marks) seems to have been from cutting a tomato and then leaving the knife sitting for a couple minutes while I finished making a sandwich. If the patina was merely cosmetic I'd pay it no mind, but the fact that the discolored areas cause drag on the blade has me worried. Have I managed to spend $200 on knives so delicate that cutting a tomato might damage them?
