Very neat tests, Twindog. Some sites have the BRKT Senegal on sale for around $200-ish. Would you say it would be a good intro to a heavy (10+ inch tool) chopper? I don't have much use for one but relatives of mine in Florida love American made stuff.
As an extra note threads like this are why I picked up the Knife Research Enki, using Vanadis 4E. I have noted similar awesome performance for me, a casual hiker/bushcrafter and outdoors person, seeing much less maintenance or worry during normal use.
Good point, Chiral. I was just seeing how well my blades stood up, as they were. I started out with the choppers at factory-set edges. I was measuring both chopping performance and edge stability, so I left them as the designers intended, because changing one factor would change the other. I did give edge acuity -- or estimates -- for those.
There is a clear relationship between edge acuity and edge stability. Acuity usually helps with wear resistance, but hurts with stability.
Here's the edge geometry of the smaller fixed blades:
M4 -- 23/16 (degrees per side)
3V -- 19/18
Elmax -- 15/15
Vanadis 4E -- 20/20
S30V -- 28/28
Is the S30V supposed to be the 1095 knife?
Talk about a clean experimental follow-up, well done :thumbup:
NOW the tougher question - what would happen if you thinned the previously thicker edges down to 15/15 and tested them again? Would the 3V and M4 and V4 hold up better than the 1095 and Elmax at those levels...?
