Horsewright
- Oct 4, 2011
Ya mean these guys? Been using em for years. This particular batch is AEB-L though.
There were very few of us interested. Gunmike1, myself, and Me2 are the only members that come immediately to mind. I was able to score some power hacksaw blades in M2 at 66 HRC from a fellow forumite in Canada who unfortunately died in a car accident. I shared these with several BF members, one who kindly made a couple of blades for me. Talk about edge retention..... I've always wondered why there wasn't more interest either. If you get 1095 at 65, it's a whole different steel, like it woke up. It would be perfect in a stockman or opinel. And contrary to "conventional wisdom", it sharpens up MUCH faster and easier at 65 than at 58, even with aluminum or silicone oxide stones. Very little burring.Have to ask why did everyone stop? Everything about it sounds too good like I'm just waiting for the hammer to drop on an "oh duh" type moment.
Does anyone have any experience with knives in 1095 or similar simple steels that aren't stuck in the realm of 55 to 58 HRC??? I've been following someone on YT that had a custom maker do a smaller fairly thin fixed blade in 1095 at a 60+ HRC. Some light wood processing and a little not overly harsh baton use but enough that I assume the edge would crumble or a whack later and it would crack. Nope. And the knife still cut through paper. Which I know is not the end all be all test but once again you would think it would be all chipped and rolled and instead swoosh right through.
So what gives? Just the most lucky person or is there some other reason we don't see 1095 any harder than the usual???
It's not really a concern in the production setting. When the steel is bought and received it is in the annealed condition from the mill. Manufacturers often have there blades cut out from the sheet with laser or water jet including the holes for the handles. All of that is done before sending out for heat treatment.
There can be some important details missing in the HT causing problems even at the same HRC
For a custom knife, you also drill the holes in the tang before hardening not after so it's not a factor.
As far as chipping during finishing, that is a big sign that the heat treatment is straight junk or very poor practices are being used which either can be ruled out.
Here is an example, I made and heat treated a knife in 1084 which is 64.0rc after tempering.
After finish grinding in prep for hand sanding, no chipping, again handle holes drilled before HT.
After hand sanding and tapering tang nice and thin again, no chipping.
[Video]
After finishing and sharpening the knife, no difficulty in sharpening and no chipping.
Now we can certainly use a different heat treatment and temper to the same hardness and make it into a chippy brittle piece of junk.
Microstructure, Microstructure, Microstructure.
Similar to Spyderco making a true zero ground edge and then having to add a secondary bevel, there is no room for forgiveness with such heat treatments.
Alvin Johnson was the makers name. He ground his blades straight razor thin and hardened them well above what most people use for knives. O1 at 64 JRc, 1095 at 66 HRc, A2 at 63, and M4/M3 at 65 were his steels of choice. However he made kitchen knives and replacement blades for slip joint pocket knives; nothing you’d ever want to baton.
.... But above all at least 60-62 HRC.
Is Alvin still around with these? We used to talk via Bulletin boards years ago. I've always wondered what happened to him and if he's still playing around with the high hardness blades.I was able to test one of Alvin Johnson's blades. He sent me a large stockman that he had rebladed, and the edge retention was very good. He also ground it very thin so it was a real slicer. However, before I even received it, the sheepsfoot blade had broken, evidence of a little brittleness at the higher Rc. I had to return the knife, but he let me keep the broken sheepsfoot; I still have it.
... is this the order thread?It's not really a concern in the production setting. When the steel is bought and received it is in the annealed condition from the mill. Manufacturers often have there blades cut out from the sheet with laser or water jet including the holes for the handles. All of that is done before sending out for heat treatment.
[Video]
I'm not here to sell my knives, just adding to the discussion.... is this the order thread?
Simple answer, because I want it.I like the idea of a simple, high hardness slicer. Minor point: you'd probably rather have 1084 or 80CrV2, as it's my understanding that they'll be simpler to heat treat and outperform 1095 on toughness by a wide margin while offering no tangible downsides.
A question I would ask, though, is if I were to ask a bladesmith who's capable of making custom heat treated, high performance knives to make me something in 1084, why wouldn't I just ask them to use AEB-L or 14C28N? The steel cost difference is minimal and their work and expertise is going to be expensive either way, so I'd think you'd get more for your money by selecting a simple steel that has a better overall balance of properties. I don't mean any offense by that question; I would love to understand what about 1084/1095 makes folks happier than using the high edge stability stainless options.
I suspect you would get some answers like "because that's the way it's always been done" or similar.There are a handful of recent fixed blade companies making soft 1095 knives but it’s not as if 1095 has never been heat treated above 60 before. Lots of knives in 1095 in the 58-61 Rc range, and of course some that are harder. Below 58 is a pretty low target for 1095 I don’t know why these companies have been copying each other in recent years.
