Higher Tempering Temps needed after Cryo??
I ht 440c for the first time this weekend. Along with a few other steels...
20180324: HRC at peak/AQ and 400F tempered:
A2 67, 64 https://www.alphaknifesupply.com/Pictures/Info/Steel/A2-TC.gif
Cruwear 67, 65 https://www.crucible.com/eselector/prodbyapp/tooldie/cruweart.html
RWL34 66, 65 http://www.damasteel.se/files/8414/5670/2913/flyer_rwl34_A4.pdf
Becut 63, 60.5 http://www.bestar-steel.com/wp-content/uploads/BECUT.pdf
440C 65, 63 https://www.alphaknifesupply.com/Pictures/Info/Steel/440C-TC.gif
W2 Chopper 67, 65
CruforgeV Chopper 66, 64
https://www.alphaknifesupply.com/Pictures/Info/Steel/CruForgeV-TC.gif
20180325: *not 400F temper yet - time to zzz
S110V 66
M2 67
M4 69
W2 Chopper 67, 65
S110V 66
M2 67
M4 69
Don t get me wrong , but what's the point of your post in this topic ?
W
W2 Chopper 67, 65
S110V 66
M2 67
M4 69
Wow you got an as-quench of 65 with 440C and 63 with 400F tempering? that is very strange for me... I'm very familiar with these steel and never ever heard it has as-quenched hardness over than 62... all of your number are absurdly high. are you sure your rockwell tester is accurate...
Is it possible that Austentizing temps that are TOO HIGH can effect the numbers? I am 100% sure now, that my toaster oven, and my kitchen oven are within 25 degrees accurate. The heat treat oven MAY be off though... and i may be getting the steel too hot?
I think you've got it figured out but I just wanted to say yes, some steels react with lower hardness from aus temps that are too high. I struggled to get S7 60 RC out of the quench, even oil quenching it, from 1750F. Backing off to 1725 got me 61-62 as quenched.
Point = Op's 440C 400F tempered HRC# is similar to my. So as his A2 ;)... so perhaps OP should go back and repeat original ht process to compare with his recent ht #s.
440C HRC fall in line with other stainless steels #s. I calibrated the tester whenever #s flux more than 1rc, also use opinel knife as 57rc blade/block. However the tester may be fine with calibrating blocks but not accurate on hrc above 61.9. Oh, I just remember: I could use the 3V chopper Nathan tested as a 65.5rc block (probably +- 1rc flux on a blade).
W
