- Jan 20, 2008
There have been lots of threads asking about the best hard-use folder, but this is a little different. What are some of the lowest priced, truly hard-use folders?
I consider a benchmark to be the Cold Steel Voyager (large Clip point). Under $50, excellent lock, 3.5mm blade thickness, and AUS 8 steel. I am not sure about the toughness of AUS 8, but I don't think there is something stronger for the price. For the extra money, does the AK-47, Recon 1, or American Lawman really add more strength? The handles are nicer, but the blades are also hollow ground, which isn't quite as good as the flat grind on the Voyagers.
A notable higher-end option is the Benchmade Adamas. It is more than 3 times the prices, but improvements are D2 steel blade that is 4mm thick and the well proven AXIS lock. I suspect it is one of the hardest-use folders for the money. Hinderers, Striders, CRKs, etc. are all tough and amazing knives, but I'd argue that the increase in money does not go into more toughness. It goes into finish, attention to detail, tolerances, warranty coverage....
Thoughts on the best value for a hard-use folder?
