Hillbilly - 10 minute - On the fly work rest
Fiddleback
Knifemaker
Moderator
So a lot of the time I need a work rest for just a second, then want it out of the damn way. Usually, I just make do without because screwing a bolt under the KMG workrest arm takes time. Sometimes I want the work rest to come in front of the belt and sometimes I want to use it with one finger for stability. THe other side has the arm, and I can usually get my finger on that. This is important for re-plunging blades on the fly during finish grinding. At least, thats how I am comfortable doing it. So, the other day I came up with this, and it has helped a lot.
You can grab it and pull it in front of the belt, use it, and push it out of the way in a second. I put a stop on the bench so you never run it into the moving belt. The first pic is with it closed in front of the belt. This next pic is with it opened up and out of the way.
The rest pivots on a wood screw that runs through a stub at the back bottom of the 2x6. In the pic below you can see the pivot and the stop. One thing. You must place the rear pivot far enough away from the grinder to safely remove belts.
This pic shows it closed with the workrest in place. THe workrest is on a pivot also, and can be bumped out of the way as well if I'm just using the plank 'arm' to stabilize my hand during small grinding operations like re-plunges.
Finally, this is how the underside of the workrest looks and functions. Its a dowell in a hole with a stop on the bottom so that it doesn't get into the belt when you move it into work position.
All of the grinders will have one of these soon. It didn't cost me a penny, all scrap. In addition, I did all the work in 10 minutes between knife steps. Not pretty, but very helpful.
"I'm o make me a tool ress ouda dis'ear scrap wood.... here, hole m'beer."
If it works, its a success, bud. It's pretty enough for my shop.
I'm going to nominate this one for best redneck engineered grinder attachment of 2015....see you at the award ceremony
awesome, and if/when you change attachments you can drill for the dowel in different locations.
Yes. You can continue to add drill holes to fit different attachments!
Steal away Nick.
You smell somethin' burnin'?
:D
It's only awesome if you make it from scrap off of a pallet, Andy. Or wood you stole from your neighbor's front porch...;)
I also drilled a hole to stick the end of the compressed air nozzel into so I don't have to continually reach for it. Woot.
Ha... i second the nomination for best redneck grinding attachment of 2015, and am myself going to steal this idea. For the record, i will be stealing this wood from work, so it counts as a "double steal" for points. I just got something for nothing... everything's coming up millhouse!
Nice. A Double Steal score. Thats impressive.
And additional points for the obscure vintage 'Simpson's' reference. :D
ya like references eh? then, this is my last post on this thread... always end on a high note. George out.
