They are both FULL TANG too.Two completely different ways of putting a knife together.
Full-Tang Construction:
Hidden-Tang Construction:
There......not difficult to understand at all......but perhaps easier with pictures.
Similar, but definitely not the same.
They are both FULL TANG too.![]()
The bottom drawing is similar to the BUCK barrell nuts in the early 60's.
The NEMO was never a barrell nut ,the 1st version NEMO had 4 pommel pins in it through
the full tang.
Sounds cool.
Maybe you have a diagram you can post.
Still doesn't sound like a real full tang if all those pins are in the pommel.
A full tang would have some pins through the handle (like they do with the 124) not just the pommel.
Sounds like it's still just another hidden tang.
So pins in a handle and the pommel make a full tang,and a NEMO with pins in the handle would make it a full tang also?
It would usually have two pins through the handle from side to side......just like the 124. Maybe three like the nice old Kalingas.
As long as you can see that tang all the way along and around the handle, front to back, top and bottom......it's a full tang.
If you can't SEE the tang.......how could it be full? If it were full you'd be able to see it.
If it has a blob of aluminum tacked on the end of the tang.......it CAN'T be a full tang, only partial.
Full means full and NOT QUITE full means--partial.
I understand that Buck likes to call their 102s, 105s, etc. all the way out to 120--FULL Tangs.
That's ok, all's fair in love and marketing and many people agree with them.
When a knife has a nice big blade that suddenly gets much narrower at the hilt......that's not a full tang and it's also a knife that will break right at that point when you're killing a bear or doing other tough work.
Like this one......the guy even says, "If it would have been full tang it wouldn't have broken."
http://www.youtube.com/watch?v=qaB1D_w0dYU
Did you read the comments on the video?
No offense but you should have known better then to batton with a rat tang to begin with... Thats what full tang knives like the kabar becker series and Esse and ontario knives are for.
