alphatiger
- Oct 8, 2014
HK P30L Comp Weight. Used Once. Mint.
The HK Parts P30L Comp Weight™ is the world’s first quick detach Comp Weight™, compensator. That slides effortlessly onto your pistol frame and locks into position in seconds. No tools, or screws required. The perfect addition to your HK P30L firearm with our low profile, aggressive Comp Weight™ that flows with the lines of the firearm for a seamless addition. Our Patent Pending design allows the user to install and remove the unit on a moments notice, without tools or disassembly of the firearm. The HK P30L Comp Weight™ can be used with the standard length and tactical length barrels. The Comp Weight™ doubles as a compensator as it directs pressure down on the frame to reduce recoil, increase accuracy and less muzzle flip. Each unit is made 100% in the USA.
Quick Detach - Comp Weight™ - HK P30L, P30LS Compensator - HKPARTS
- CONUS Only
- No PO Boxes
- No Trades
- Zelle / PP FF
- Shipped with Tracking via USPS
**** $86 TYD!!!! ****
- HK P30L, P30LS 9mm
- HK P30L, P30LS .40 Cal
- CONUS Only
- No PO Boxes
- No Trades
- Zelle / PP FF
