Buck110, not sure about cryo treatments to relieve stress in alum, titanium and cast iron ect. (NASCAR) but in a high alloy knife blade it is most effective right after the initial quench. Again to yield full conversion to martensite, a very stressed condition. Tempers will modify the crystal structure to a more relaxed state and reduce the stress and hardness and improve ductility. If the cryo cycle is not done some temper techniques can reduce the retained austenite for more martensite conversion but this is not as effective as the cryo treatment. If the cryo cycle is done after tempers and it does in fact move some retained austentite to martensite then you have some untempered martensite, which is again adding stress to the blade if left in that state. Another temper is required to modify the martensite structure. Tool steel data sheets recommend that a temper cycle always follow cryo treatment. This whole discussion on relieving stress with a cryo treatment is controversial. I recently spoke with a rifle barrel maker who uses 416 SS to make custom match barrels. He has deleted the cryo cycle and instead does multiple tempers after the final machine and finish work and claims better results. To answer the original poster and his question, a cryo cycle on 154CM is very benifical. Quenched 154CM can have as much as 30% retained austenite after the initial quench. A cryo cycle will reduce this down to around 5% as per my metallurgist mentor. The point is it has to be done in the correct sequence and just saying "cryo treated" does not mean that the steel has been improved for a knife blade. Phil
