- Jan 16, 2006
Jim, As I mentioned cryo treatment is controversial. Some Metallurgists’ will tell you that if the heat treat was done right in the first place then it is not necessary. My take is to do it right in the first place and use a sub-zero cycle to squeeze out the last bit of retained austenite and also as a final quality control measure. Multiple tempers at the “high” end-- 975 vs 400-- for example will do close to the same thing as cryo cycle in LN2 right after the quench. Problem is that the high end tempers also can have negative effects on corrosion resistance and ductility. So it depends on the steel you are working with and where you want to end up. Some tool makers want some retained austenite since it tends to cushion the force when a tool like a milling cutter is pushed hard.
Yes, the fact that this particular maker advertises and uses a cryo cycle does not automatically mean his 154 CM is better than someone else’s. In order to judge that we would have to know his process. In the end it is how the blade performs that is important. Phil
